So I have been having these fuel pressure issues for about two months now, and so far this is whats been done....
-Replaced Fuel Pump 3 times just to rule out a faulty fuel pump
-Replaced the FPS
-Replaced Fuel Filter
-Swapped PEM in the trunk with another one from an 08 2.5T, same P/N
none of these have solved my issue even after clearing the code via VIDA, the codes that are showing are:
ECM-290B (Fuel Pressure Signal missing)
ECM-290C (Fuel Pressure Signal to high)
Car runs perfectly fine, performance is fine, no hiccups no start up issues or anything, drives perfectly normal.
Any thoughts? I saw another thread that was not answered however that post mentioned about wiring could cause it
-Replaced the FPS
