Folks,
Followup if I may (post #7 in this thread)?... I have a problem nobody seems to want to help resolve (even with me paying for it)
Car has been perfect post TCV changeout & adaptation. Power (low end boost) and Econ (26-27 mpg highway stable 93 octane gasoline) all per normal operation.
6 weeks ago, car went to dealership for maintenance (alignment and simple checks). Upon exit, no boost, no fuel economy.
Took car to other dealership in town after call to VCNA. Results: Tire balance improperly done; alignment improperly done.. had bend in trailing suspension arm due FOD strike.. very visible by tech.
Dealership checked entire vehicle and test drove. They conclude boost low/non-existent but find no faults/leaks.
I've driven over 1000 miles attempting to retrain. Unable to 'retrain' the system. Engine performance (as if natural) starts gaining strenght at 2500-2700 rpm, reaching maximum around 3000-3500 then plateaus.
Gas mileage in the toilet. 5-10 mpg around town (previous 18-20), highway 15-18 mpg at stable cruise 65 mph level terrain.
I have since learned (been educated by the tech) all adaptations were purged/cleared, which describes what i experienced immediately upon leaving first dealership (one's who caused
Today I performed a complete adaptation reset/clear and immediately took the car out on the limited access highway (interstate). Set the cruise. Drove 180 miles out and returned (360 rt)
Fuel gauge shows approx 1/3 tank remaining. D.I.M. calculations with odo reading indicate ~450 miles full tank range (compared with 475-480). D.I.M mpg display indicates 22 mpg which doesn't match it's range calculations & trip odo.
Boost non-existent (or VERY low) until ~2500 rpm as before. I *think* i felt a flutter around 3800 rpm under 3rd gear load. power 'dropped' suddenly and only momentarily, then immediately returned.
Engine starts and idles fine but a ) very low-throaty, almost gargly exhaust note, frequently smell 'hot exhaust' after vehicle shutdown. These are not normal.
Question: Given VIDA can be forced to overwrite and the dealership in question refuses to admit any mistakes might have occurred, could the wrong maps been loaded but is being denied because they don't want to 'own the problem'?
-or- could a simple set if mistakes (which I think is the case) really dorked up the maps, hence wiping all the previous adaptation files?
My other option as I see to this point: Check CBV when I pull the manifold (have a minor exhaust leak when cold), replacing if needed with IPD. Give the actuator arm 1/2 or a full turn while turbo is off to compensate for 'new norm' on the low end.
Thoughts and suggestions?
Thanks,
C
