That could be a function of it, I beleive ANC is also connected to, or monitoring, the interior microphones. It definitely adds engine noise though. There are 2 subfunctions when it is enabled "Engine Order Enhancement" and "Engine Order Reduction" EOE and EOR. The setting are Off, EOE, EOR, EOE+EOR. The T6 comes from the factory with EOE. Since I have played with it, I was curious about what the settings do, I tried the EOR and EOE+EOR settings as well. Those just made funky noise come through the speakers. I discovered that the EOR setting, I beleive is only for diesel models.
Since changing it to Off, it's very obvious the additional engine noise is gone, no doubt about it. You might not otherwise know if you don't have that comparison. On relfecting it does make sense, the firewall is like any modern premium car, insulated very well. road noise and engine noise are well controlled. You block out all the "bad" noise and you don't have much engine feedback, so they add back in with the ANC. Seems a little excessive to me, not really necessary.
If there is any noise cancellation, I can't tell the difference between ANC on and off.
