So today I hade some time to finally go to dyno my car. I was hoping to see some good numbers. Bone stock car, just curious to see base before Ill upgrade with RICA.
3 runs with crappy fan in front of my car.
Here sheet:
I didint even get 200hp at the wheels! Im dissapointed. And what the hell is wrong with my tourque? Why after 4.5k rpm its going down and then up again? Shouldnt it be at least flat? The guy at the dyno said I might have some leak, or Im running lean, but everything seems to be fine.
So i need help what I can do before RICA upgrade.
I went to Volvo dealer to ask them to check my boost pressure, if I dont have any leaks - they cant do that because..... they cant... Suckers.
Vadis - checked - everything is ok.
Maybe You guys know good shop in LA/OC area so I can be helped?
Here sheet:
