Been a while since I've posted on here. Thought I'd share my axle woes for the next person that falls prey to a stuck axle.
My driver's side c/v axle has been causing increasingly worse vibration under acceleration so it needs to be replaced. I decided to attempt to do so on Saturday. Everything was going great until I tried to release the innner splines from the transmission. I tried every trick known to the internet. 5/16" cold chisel, screwdriver, spinning the axle and hitting it in different positions, even wrapping steel cable around the inner cup and trying to yank it out. No dice.
I put everything back together and decided to let my indy have a shot at it. They have the Volvo special tool. Well, they couldn't get it out either. They said mine is only the second car they've had this happen with. So plan B is to get a new Volvo axle, take the cup off and fix the rest of it to the cup that is stuck in the trans. Wheeeeee!
Whoever designed that circlip is a moron. I can't believe I have to contemplate junking the car over a POS circlip.
