Diagram for intake/turbo set up?
7.3K views 5 replies 4 participants last post by  Bender
Just wondering if anybody has or knows where I can get a full diagram of the entire turbo/intake/exhaust setup on the S60, with vacuum hoses, wastegate, blow-off valve, everything.
I have the 2.5 T, btw
Thanks in advance
Re: Diagram for intake/turbo set up? (jstro)
Quote, originally posted by jstro »
Get a VADIS disk from E-bay or download from bit torrent
yes cause there is some diagrams, not just one.
boost gauge install: http://forums.swedespeed.com/zerothread?id=98434
as for the method used instead of a blow off valve - it is done that way as it measures airflow on the outlet to ensure everything is working properly some will claim you can install a B.O.V. but there is no purpose to and you WILL eventually (if not immediately) get a CEL.
