First contribution to this XC90 forum, hope it can help someone!
A few weeks ago the cluster on my '16 XC90 (Canadian version so kilometers below) started acting up and eventually went completely dark:
Unfortunately I couldn't find much online on how to replace it, and the dealer was asking for a disproportionate price for a replacement. After a quick look at eBay I found a similar cluster locally that got pulled from a 2020 S60 Momentum. It looked identical to the one on my XC90 so for $150 I figured it was worth a try.
Removing the cluster on the XC90 comes down to 3 screws (for the plastic panels under and above the steering wheel), two screws for the cover on top of the cluster, and then 4 screws for the cluster itself. I recommend buying a set of plastic tools to pry and pull the other items in the way of the cluster otherwise the plastic will get damaged. Accessing and removing the cluster took me about 45 minutes and a lot of guessing. Can probably be done in 10 minutes if you know what you're doing.
Once I removed the original cluster I simply disconnected the two cables behind it and plugged the one from the S60. It just worked (minus one nuance - the fuel gauge was always showing an empty tank)
Some anomalies about "City safety" we're also showing up. This could maybe have been reprogrammed at the dealership but I avoid them like the plague. I then took a look inside the original cluster to see if I could find anything interesting:
My theory at this point was that the original screen was likely broken but the cluster board was fine. Swapping the board (which is really a standalone ARM computer) could do the trick. At this point I had both clusters open:
Swapping the boards, I ended up with a reconstructed cluster with the original board from the XC90 and the screen from the S60. A quick test validated the theory:
Fuel gauge is working again! At this point I simply put everything back together and screwed the cluster back into place.
Conclusion: cluster screens from different Volvo models from '16 to '20 (at least) are definitely compatible. The cluster itself is kinda compatible with some anomalies such as the fuel gauge.
A number of cluster issues reported on this forum could have probably been solved with this low-risk, $150, two-hour surgery.
