Now you will have both turbos on the bench.
Should have asked before but why no 18t on the 98 T5M? (Great match, tuning is easy).
CHRA is held to the hot side with a v band with a 10mm nut. Hand tools only! Its stainless, will gall and break if you use an impact driver.
Once that clamp is off, turbo "would" come apart. But exhaust carbon, oil coke ect basically glued them together. Youll need a 2 lb hammer, holding the turbo compressor side up, tap around the outside of the exhaust housing. Evenly, not too much force, if it cocks you can ding the turbine and or bend the shaft. Have something to catch the exhaust housing when it drops. Be careful and gentle minded with this operation.
When the hot side comes off, chase the threads on all the holes/studs before reassembly.
Assembly:
You will see a pin, or remains of a pin and the corresponding hole in the turbine housing/CHRA. Make an external alignment mark with a sharpie across the split in that location. Do not reuse the pin! Pull it out or break it off. Trying to pull the housing together with that pin will **** the CHRA, ding the turbine or bend the shaft. V band holds the turbo together very effectively. Make a second alignment mark at 11 o clock looking down the turbo, from the compressor side. This is where you'll set the gap on the V band and can watch the alignment while you tighten the clamp.
Hand seat the CHRA into the angle flange hot side. If it doesnt seat evenly/casually, clean the mating surfaces of carbon/coke ect. Both of them! The tolerances are fairly small between the turbine and the housing, little room for off angle assembly without damaging.
Once the CHRA is seated correctly, aligned and clocked as necessary, attach the v band.
Beyond this, assembly is the reverse of install.
