C70 (2001) Electrical Short - door chime/interior lights
4.7K views 5 replies 4 participants last post by  mhbva
I just acquired a 2001, 85K/mi.-young C70 Cabrio and have been steadily "restoring" it.
Out of nowhere my courtesy and map lights went out leaving me with the annoying and continuous chime. I traced the issue to a fuse (#15) and replaced it. It worked for all of 10 minutes. When I attempted to replace it again the fuse slot just sparks and blows the fuse immediately. It would seem that there is a short somewhere.
Anyone out there have this problem - and more importantly resolved it? Any clues or spots to look? Are there any easy sure fire ways to find the culprit? Any help is greatly appreciated. I really love this car and am anxious to get it right.
Thanks,
Marc
May be you got a pinch wire some were bad light socket don't for get lights in the door could be where it goes from the door to the body every time the door opens the wire bends back and forth in that rubber tube jest trying to help
I had a similar issue, and was able to trace it to my GPS unit tied to my cigarette lighter plug. If you have anything plugged into your cigarette socket, remove it and see what happens.
I had the same problem in a '99 coupe -- constant chiming and no interior or trunk light. I removed the chime from under the dash after going through a box of 10 amp fuses. One day the key wouldn't turn and when I replaced the ignition switch the lights came back.
