Battery light (new battery and new OEM Volvo Alternator) error code DD30
4.5K views 6 replies 4 participants last post by  2birds
Hello everyone!
I was wondering if someone can chime in with the problem I’ve been trying to figure out in days!
I recently bought a 2007 S60 2.5T that runs flawlessly. However, there was this red “System power Urgent” warning with battery light. So I quickly assumed it was the alternator even tho previous owner mentioned the light was on for 3 years.
fast forward after installing a original Volvo alternator, the light was still on so I brought it to my local mechanic and had it scanned for codes.
there were a few that was on but after reset only 2 quickly appeared again.
Communication with the Alternator Control Module (ACM). Signal Missing
Alternator Control Module (ACM). Voltage Too High, B525412
I checked that the regulator wire was inserted properly and it was.
quick note current voltage from battery post is 13.5 - 13.6 while car is at idle
Regulator wire voltage measured with volt meter = 6.5V while car is in ON position (engine off)
Would this me a CEM problem or is there something I should look for before replacing the whole module?
Thank You in advance!
There are two different alternators (different voltage regulators) for the same engine depending on year make of the car. 03-04 does not communicate with the CEM. The 05-08 does.
Check so that you don't have the wrong type.
The average LIN voltage is 7-8 volts. 6.5 volts is probably OK.
6/25 = starter
6/26 = Alternator
Since you have 6.5 volts at B1, I would assume that the CEM is sending out the correct
LIN voltage and signal to the ACM. Not knowing the code, I picked this one for voltage too high.
I am not sure what is causing the message. Did you install a new or used alternator?
The bottom pics are the CEM. You could remove the wiper cowl, top CEM cover.
Inspect both CEM connectors/pins B and C for any water damage or corrosion.
Check out xemodex.com about this issue.
Available Services for 2005-2014 Volvo Central Electronic Module | XeMODeX Inc.
6/25 = starter
6/26 = Alternator
Thanks for all the info! I find it weird that only the alternator is having an issue according to the scanner. Is there a possibility that my regulator is defective?
Some of the alternators had a freewheeling clutch (built into the drive pulley I think). This might have been a manual transmission only kind of thing, but maybe if your car is expecting a freewheeling alternator and you have a fixed drive system or vice versa, could lead to unexpected voltage excursions. Just a thought
