B20E rated power mystery
1 reading
8.5K views 6 replies 4 participants last post by  142 Guy
I happened to be looking at a .pdf of the owners manual for the 1800ES and noted a reference to the use of the B20E engine with a power output of 135 hp. Given the start of production dates of the 1800ES, I found both the reference to 135 hp and the use of the B20E odd. So, I checked the Wikipedia for the B20 and I found this:
B20E: 10.5:1 compression. Bosch D-Jetronic electronic fuel injection up to 1973 then K-Jetronic mechanical fuel injection from 1974 on. 130 bhp (96.9 kW) for 1970 and 1971 and 135 bhp (100.7 kW) from 1972. First produced in 1970.
B20F: 8.7:1 compression. D-Jetronic fuel injection up to 1973 then K-Jetronic fuel injection from 1974 on. 118 brake horsepower (88 kW). First produced in 1972 for lower emissions.
So, was the B20E retained for use for non North American markets after 1971 and if so, does anybody know what was responsible for the 5 hp increase in rated output for the 1972 version? Was this perhaps just a change in rating method in the non North American market as opposed to a true increase in output. Did the 1972 version of the B20E switch to the K cam or did it continue to use the D cam? If it weren't for the reference to 135 hp in the 1800ES owners manual I would be inclined to believe that the 135 hp reference on the Wikipedia might be a sourcing error.
My understanding is that it has to do with the head depth and head gasket thickness. The B20Fs used a thicker head gasket. I have my ‘72’s engine out right now for a total rebuild and part of the performance upgrades is decking the head to increase compression and using the E gasket. Both E & F FI engines for 71 &72 used the D cam I believe.
#4 · (Edited)
My understanding is that it has to do with the head depth and head gasket thickness. The B20Fs used a thicker head gasket. I have my '72's engine out right now for a total rebuild and part of the performance upgrades is decking the head to increase compression and using the E gasket. Both E & F FI engines for 71 &72 used the D cam I believe.
No on the cams. In North America all the fuel injected cars were equipped with B20F engines starting in 1972 and the B20F definitely got the K grind camshaft as part of the emissions control package for 1972. The K grind has a nudge less overlap which makes it idle better. Max lift and the timing events are the same (when measured at 0.05" lift). Edit - I HAVE BEEN CORRECTED. THE F ENGINE STILL HAD THE D CAM FOR 1972 AND PERHAPS 1973. I FOUND A REFERENCE THAT SUGGESTED THAT THE K CAM DID NOT COME UNTIL VOLVO SWITCHED FROM D JET TO K JET IN 1974.
http://www.1800philes.com/ianr/_superlist_grinds.html
Be careful in your search for a true E head gasket. I found out from Phil Singher that the head gaskets that come in the bundled top end gasket kits for fuel injected B20 engines are all B20F head gaskets, even if it is listed for a 1970 of 1971. This helped explain why my compression tests never came out quite right after I rebuilt my B20E with an Elring gasket set. You can get a gasket of the correct E thickness (check the 1971 service manual for specs) by ordering one from Cometic which are available in a wide range of thicknesses for the B20. Cometics are a tad pricey and require a high quality finish on the block and head surfaces. Phil advised that the budget way to get a head gasket in the correct 'E' thickness was to purchase a gasket for a Volvo 1971 or earlier B20B. I have not checked the service manual to confirm that the thicknesses are the same; but, that is my plan if I ever get sufficiently motivated to pull the head to rectify the problem.
I am aware of the 1971 - 1972 change for US spec cars. What I was curious about was the reference to the B20E version being available in 1972 and that the horsepower had increased from 130 to 135 hp. The 1972 1800 ES owners manual I was looking at was in English so presumably the 1972 E engine was for Great Britain and perhaps Europe? I was really curious about what change was made to the B20E between 1971 and 1972 that resulted in the 5hp increase in peak output.
Here you go.
The 1971 factory service manual specifies a thickness of 0.031" (0.028" compressed) for both the B and E gaskets.
I did find the thread in the pushrod performance forum discussing the issue (with the thicknesses).
https://forums.swedespeed.com/showthread.php?270145-B20-head-gasket-thickness
Turns out that the Elring B gasket is still a nudge thicker than the service manual value for the B & E gasket. Phil advises that it crushes to around 0.033 - 0.34" which leaves it thicker than the 0.028" specified for the B & E gasket. If you check the MLS web site they do not differentiate the gaskets between B20A, E and F applications, so the intrusion on the fire ring with the B gasket in the E head that Phil mentioned does appear to be a non issue.
If you want a true 'E' thickness head gasket, I think you are going to have to go with Cometic. The only thing I have not been able to confirm is whether the advertised thicknesses are the uncompressed or compressed thicknesses.
The other uncertainty I have is with the 90mm versus 92mm bore option on the Cometic gaskets. I had always assumed that the 92mm bore option was for people who were installing B21 pistons in their B20 to create a larger engine 2.1 l engine. However, I did stumble across some information suggesting that the fuel injected heads have a larger 92 mm combustion chamber diameter. Once again there is conflicting information as to whether this change occurred starting with the 1970 E head or another source suggesting that it occurred with the 1973 or 1974 F head. Maybe its all conjecture. Maybe the only way to put it to bed is to measure the combustion chamber diameter. As a further side note, the old spec sheet for the B20E/B20F Elring head gasket in my engine specifies a diameter of 91 mm - split the difference????
