Hey fellas,
The OEM clutch kit is on it's way here and should arrive tomorrow. I'm having a friend help me replace the A/C clutch and pulley Wednesday night.
Heres the puller I plan to use to take the pulley off. Ignore the new compressor, it's going back immediately as I shouldn't need it if only the clutch was the issue.
The questions I have:
Is there a process to getting it off besides removing belts, unbolting 10mm inner bolt, removing clutch, and then undoing the snap ring?
How do I get the new clutch and pulley on? I don't want to straight up hammer it.
Do these clutches come pre shimmed, with the washers already inside the clutch, or if not how many do I put in?
Thank you for your help.
