Anyone removed the door panels?
26K views 25 replies 10 participants last post by  bhom920
Has anyone here taken the door panels off of the XC60? Pic's
Not yet. Might have to take a look next week. Gonna see the dealer about the 'clunky' sound when raising/lowering the driver window. Wish me luck. ;)
I don't have any pics but it is really easy.
First remove the triangle shaped trim piece where the tweeter and (if you have it) BLIS light is. Use a plastic tool and wedge it between the door frame and the trim piece. It should just pop off. Then unplug the attached connectors.
Under the interior door pull handle are 2 T25 screws which must be removed.
Once those two screws are removed, the door panel is held on by plastic clip pins. Wedge that plastic tool between the door panel and the door, get your fingers under and pull until it pops. Continue popping the pins all the way around, disconnect the electrical connectors and seperate interior door open cable and you're done.
#17 ·
Thanks for the pictures and instructions for removing the panel.
One novice mistake, when trying to reassemble I accidentally disconnected the rod that connects the lock mechanism to the little pop up that shows if the doors are locked or not. Tried for a good 1/2 hour to fiddle around and reconnect, but without success. Anyone have any ideas on how to resolve this? Also not sure if this is related, but I also screwed up the auto up/down feature on the driver's door window. All 3 other windows work properly with one touch of the button raising or lowering the window, but on the driver's window I need to manually hold to open or close.
#24 ·
I took my passenger side front door panel off today and it was a lot easier that expected. Just two screws under the door handle and start prying from the bottom. I was happy to see the door panel clips are not the self destructing type found in a lot of other cars. I found non of the harness I was looking for :( . If anyone can snap some pictures of their 2014/2015 platinum with the accent lights that would be great. Im curious to know where the harness for the lower puddle light comes from.
Here are my pictures I took from my 2015 RD P+:
Here's a shot of the door control module:
Another shot of the open pins on the door control module. Maybe two of these are for the puddle lights?
I believe this is where the accent light for the pockets is supposed to g:
And here's a picture of my puddle light block off :(
Here is some speaker info for anyone interested. Looks like the woofer is 2ohm and the tweeter is 5ohm.
And here's a shot of the unlock/lock button and window switch harness. If anyone knows which wire is the illumination that would be great for those of us looking to install pocket light LEDs!
#25 ·
You are right I do have the light package so I forgot that you might not have the same. I'll try and pop the door panel of and take some pics for you. Give me a few days do get to it.
