2019 Volvo S60 T6 R brake upgrade and wheel clearance
5.9K views 5 replies 4 participants last post by  Mayo
#1 · (Edited)
Trying to find out if my aftermarket wheels would clear Polestar Brembo brakes on my 2019 S60 T6 R design. Wheels are Variant Xenon 19x8.5 with ET38. The brakes I want to order are:
Genuine Polestar Front Brake Kit, Volvo S60/V60 MY2019+
Just trying to see if anyone has these brakes with a comparable wheel
It's hard to know, always specific to the spoke design. In general the -5mm of offset from stock and 1/2" wider wheel over stock are both going the right direction for more clearance. What you might do is search here or the Googlator see if anyone with the Polestar model has mounted those wheels, probably more luck that way. There is nothing different other than the brakes and the shock under there.
Gonna drop $4k on them brakes huh. I'm totally biased since I developed a front brake upgrade that works better and more economical ;-) It's a lot of dough and not a match to the brake system. They do look nice of course. The caliper is going to be the same as an aftermarket Brembo GT kit, if you had the wheels you could probably adapt an existing template from a Brembo reseller to see if the calipers would fit. It's a gamble if you don't know for sure the calipers will clear.
What upgrade did you develop? I'll be looking for larger brakes soon
Oh hi I make the UPBrakes kits for the Volvo, www.upbrakes.com. That's the SPORT kit on my car, uses the OEM rotor and I have the SPORT19 that uses the larger OEM 366mm rotor from the XC90 T8. It's for a certain type of customer that wants an honest product that is engineered specifically for the car, durable, cheap and easy to service. I love it of course lol.
