I recently had the dreaded PCV issue with my S40, where I had to replace the oil filter housing becuase it was making a howling noise. Opening the oil cap or removing the dipstick made the sound go away, but the engine was sucking a ton of air into the engine through those openings.. I replaced the oil filter housing/oil trap, and all seems to be fine.
I did notice recently though that the vacuum pump (to the driver's side of the air filter box) seems to be constantly running.. and after I turn off the car, the vacuum pump continues to run for about a minute. I don't recall this happening before, but I could be wrong. Just curious to know if anyone knows if this is normal or if there is an issue with pump or vacuum line?
Rob
Rob
