From VIDA:
Fuel pressure (Pa)
Measurement range: 50-4680 kPa.
The parameter indicates absolute pressure.
The engine control module (ECM) derives the pressure from the fuel pressure sensor signal. When idling, with the engine at operating temperature and in neutral, the value should be approximately 400 kPa.
400 kPa = 4 bar = 58 psi
Note that the above pressures refer to absolute pressure. If you intend to measure the fuel pressure at the fuel rail with an external pressure gauge you will have to subtract atmospheric pressure from the above numbers. Also note that the fuel pressure will increase with demand above a certain threshold, which means that at full throttle you will see the fuel pressure increase, but when at idle or when cruising at a steady RPM you should see around 400 kPa.
I'm not sure at what thresholds the high and low pressure trouble codes will be logged.
