21 - 40 of 2,492 Posts
Wow, for the price I might consider doing this! I wanna get a newer one with the R Design blue option though. Is there any way to tell which ones have it enabled? Or maybe its something that can be enabled via software hack?
Discussion starter · #22 ·
To get a wire connected to the DIM connector, you'll need to sacrifice a pin connector cable to break out the pins and use those to populate the two wires on the DIM connector. I had a spare fan header from my PC laying around so I broke the pins out of those.
This worked great, because there were two different wire colors, to ensure I didn't cross the signals.
You just happened to find the correct pin type for that connector? Are those the same as OEM? I'm wondering if you noticed any writing on the Volvo connector. These are probably all sourced by a few companies, most likely, AMP, TE or Molex. If we can identify the connector we could source the pin type needed which would make this conversion more PNP.
After nearly two decades of PC building, I've amassed a variety of connectors, most which are useless. :) I went with what looked right sizewise; it snapped right in place without being loose enough to pull out. I would assume it's a standard size but didn't look for markings on the DIM connector to compare.
I think I'm going to make this mod. Thanks so much for this post! I never liked the early DIM from day one and the Xemodex solution seemed like a cluster f*** to me. Under $200 to upgrade seems reasonable.
Just for reference, from the markings on your fan connector, it crosses to a Molex 22-01-2031 connector
https://www.digikey.com/product-detail/en/molex-connector-corporation/22-01-2031/WM1576-ND/1090454
which uses a couple of pin types but this one looks like the one you used
https://www.digikey.com/product-detail/en/molex-connector-corporation/0008650805/WM2756-ND/1130600
I think I'll pull my DIM this weekend to add the wires before it gets too cold in my parts. Then I can just pop in the TFT DIM when I find one. I'll see if there are any markings on the DIM connector while I'm at it.
Discussion starter · #25 ·
Thanks!
My only issue still bothering me somewhat is the TPMS. It is not a low indicator, but a service malfunction. Not sure if my local Indie can find a way to fix that or if it is a issue with how the 2015 the DIM came from was set up (did it have the sensors or did it do the wheel speed/ABS method?).
I plan on reinstalling my DIM in to see if the system behaves again, just to eliminate any variable with my stock car setup.
Thanks!
For reporting purposes, when I had the non functioning DIM installed I got a TPMS malfunction light as well. I will see if it does the same when I get the new (to me) unit in on Friday
Discussion starter · #27 ·
Good deal! Let us know.
I went out and swapped them, and indeed it is the DIM. There are no warnings or malfunctions on my original DIM. I might just take the plastic cover off and place a piece of electrical tape there to cover up the light... :)
Quick question (or maybe more than one).
p.rico - Does your 2012 have the TPMS sensors already or is this error from the new display (new display expecting to get sensor readings and not receiving anything)?
The other question is where are you finding these displays? I've looked all over the place and can't find one. Called a friend at an auto salvage yard today and he said he would keep an eye open for me.
Terms to search on your used parts place of choice (Craigslist, eBay, salvage yard sites):
TFT Display
Virtual display
Speedometer/speedo
Gauge Cluster
Head Unit
Be careful with the model though. You will have to check details or inquire to be sure it isn't from a different model (a la fits an S60 but from an xc60)
Discussion starter · #30 · (Edited)
It's the display. I have TPMS sensors, which my old display has no issue with*. I assumed the monitoring was done by the CEM and relayed to the DIM, but it seems there's something in the DIM that's looking for that car's sensors...
*After this post to assure myself, I placed the older DIM back, and confirmed that there were no errors. Then placed the newer in and again and the TPMS error is back.
Discussion starter · #33 · (Edited)
Do you know for sure an XC60 display won't work in an S60? There seem to be more XC60 displays for sale than S60s.
No.
Want to be the guinea pig? :)
In all seriousness, there is one right now for $185 with return accepted (buyer pays shipping). Wouldn't be a huge loss if it didn't work.
When did volvo change from wheel sensors? I'm wondering if a 2014 TFT module uses wheel sensors?
This is my current thought as well. Just waiting on on the DIM to be delivered today (another 2015). This is a 2015 one and it seems that those are vastly more populous vs the 2014s (sales data?). Possible that 2015 or the 2015.5 model went to the different tpms style and that's causing the error?
Test for sure(if you can afford/stomach the risk)! It would be nice to get more of a sample size, but I think general consensus is that it won't. Possibly due to some vehicle identifier when programmed new?
I wonder if it has more to do to the part number since there are various part numbers it seems vs the spare number
Well, not what I was hoping for a pre-Christmas present to myself....
The new DIM did NOT have a TPMS malfunction indication on installation. The TFT screen.... well that didn't work again.
OLD (1st Purchase) DIM: Spare # 36010100, P 31433332, T 0642838
NEW (2nd Purchase) DIM: Spare # 36010019, P 31412534, T 0394741
I wonder if it is possibly different wiring done between trims/model years? I just would have to be pretty unlucky to get two shot units
I received my DIM today and just had to try it out this evening. It appears to work! It's from an 2015 XC60. Even the car picture looks like a S60! The salvage yard that I purchased it from said it had 45,000 miles but after it powered up it read 70k. Soon there after is showed my mileage 66k. Part numbers: Spare 36011320 (T) 0458465 (P) 31394750
Tomorrow I'll connect the CAN bus and give her a spin. No TPMS warnings but I suspect that might occur after driving. Now to find some pins that might fit :)
Great to hear, maybe I will start looking for xc60 units as well. It is weird that two didn't power up for me and am wondering if there is another factor (Sensus 2 vs 3 etc.) Interfering
The TPMS malfunction should show up immediately on plug in / power up in the bottom left. I would guess you are in the clear
Discussion starter · #38 ·
This is all very interesting! So we know a few things:
1) XC60 TFT works on the S60.
2) Mileage doesn't seem to matter, it I'll read off your CEM.
3) TPMS is conditional based on which way the donor car read tire pressure.
EcoDrive, do you have the same color on your Elegance theme (gray) or is it different (brown/blue)?
Discussion starter · #39 · (Edited)
There has to be a software issue... What version do you have? I had mine recently updated to add the USB NAV update capability and received Sensus 3 in the process. I have version 1210 now.
Sensus 3 which I can tell by the option for trip statistics but I am not sure how to check the actual version number
