Before putting your air suspension equipped Volvo on a lift you need to go into the menu and disable the air suspension. My question is can I do this if I take it to a garage for changing tires and disable the air suspension prior to handing the car over to the mechanic? Can it be driven a short distance and still remain in the air suspension disabled mode? Or does the menu option need to be clicked after the car is on the lift prior to lifting the tires off the ground?
