Hi All,
A couple of days ago my 2007 S40 T5 AWD suddenly lost all its top-end power (3.5k RPM and up), and has driven the same ever since. Low end torque is still pretty good (although maybe not 100% of what is used to be), and top-end feels as though it's less than what a naturally aspirated 2.5L 5-cyl would have.
Here's a list of some relevant info:
Any ideas as to what this might be? I've done some reading and TCV seems as though it may be the culprit, but not totally sure. Thanks!
These threads seem related:
http://forums.swedespeed.com/showthread.php?228028-Limited-Boost-Pressure-Bad-TCV-Other
http://forums.swedespeed.com/showthread.php?163933-Unsolved-problem-getting-expensive-2005-S40-T5
http://forums.swedespeed.com/showthread.php?206702-Failing-turbo-control-valve
- Can still clearly hear the turbo spooling up
- Turbo is whistling louder than usual, but no obvioius 'dumping' sounds
- Gear changes are off - sudden and rough changes
- It seems like the engine is cutting the timing to protect itself. I thought when I went to a full-service gas station they may have put regular gas in, but I no longer think this is the case and have been through close to a half tank of premium now
- While accelerating at higher RPMs revs will sometimes even drop a little bit, not consistent pull
- The car starts and idles perfectly
- No CEL or other warnings - battery seems to be fresh as it only cranks once or twice before starting
- I don't push the car until it's fully warmed up, so I don't know if this develops as the car is driven for longer
