Took apart the angle gear and collar sleeve today. I had assumed it was the collar sleeve that was the issue so I had the replacement kit. Mechanic friend tells me the collar sleeve is fine, photos confirm it is. Angle gear shaft looks good too. So is it an internal angle gear issue? VIDA shows no issues for the Haldex pump or anything. I replacement the pump temp/pressure sensor last year.
What else can go wrong to eliminate your AWD?
