Took my engine out last week, the corrosion is just too annoying and it's easier to clean it up with the engine out of the car. What started as a 15g swap has turned into a full engine bay teardown.
What I'm doing:
Head gasket (mild external leak)
Sump o-rings (no symptoms of failure)
15G
R Manifold
ARD Green ME7 Tune
Any other assorted seals/wear items that may break along the way
A/C Compressor
Dash will be removed, reinstalling the old, perfect OEM evaporator I replaced last summer but didn't need to
Fiberglassing the dashboard mounts
I'd love for the whole engine to be as clean as my new upper engine mount.
The engine bay will be getting a scrubdown, and these A/C lines will be getting a fresh lick of paint if everything goes right. The corrosion is eating away at everything.
Harness out:
Freshly rebuilt ready for action:
So far, I've got a pile of wire wheel attachments for removing the dusty white corrosion off of the engine parts. I don't see this as being a very easy job. I've been thinking about buying a Harbor Freight soda blaster (baking soda, safe and easy to clean up) but I don't have an air compressor setup in my garage and the cost would be prohibitive.
So, I'm forced to wire-wheel every rusty bolt and component I see. Wish me luck. I'm going to attempt having an engine that can be eaten off of once complete.
Anyone have any tips at getting the aluminum corrosion off of the engine and transmission with minimal effort? Steel wool and patience maybe?
What I'm doing:
15G
R Manifold
ARD Green ME7 Tune
A/C Compressor
Harness out:
