1 - 20 of 28 Posts
Tranny and angle gear connected
Angle gear where axles slides into
Angle where it connects to the tranny
Tranny and spline sleave where it connects to the angle gear
Rear engine mount for AWD 01 and newer cars
Engine mount and Powerstearing rack . - acutally same from 01-08 FWD and AWD cars. looks the same might be different part numbers but what ever.
AWD axle and FWD axle - same lenght just the AWD is a little buggered
Tourque Converter / Magic Box
TC in tranny
Now when replacing tranny make sure to put the TC in the tranny first otherwise it wont go on correctly and blow out the back side of your tranny
Tranny with out TC
Auto Flywheel where TC bolts to
Engine with no TC and RMS exposed
RMS close up
For new thing
And this has always belong here
Now dont forget this same AWD design its basicly / all but exaclty the same from 97-08 in all I5 Engine volvos
Discussion Starter · #2 ·
Any other pics you want to see of a P2XC / your R let me know since I will have most of this car apart here in the next week and its up on jackstands so I can get pics of anything
Re: (kmagnuss)
Quote, originally posted by kmagnuss »
I don't always drink soda, but when I do, I prefer grape Faygo.
LOL acutally had some orange and birchbeer today
link ?
over my head
Re: (Chilled Man)
Awesome...nice addition to my gallery. http://********************/smile/emthup.gif
Q: Where does the axle splines slide into?
...still don't really understand why the car is in FWD (as opposed to one wheel drive) when the angle gear collar gives out.
Re: (rushin_max)
Quote, originally posted by rushin_max »
As you see on the driveshaft there the only connection is acutally inside the tranny itself.
The rest of the shaft is smooth and has no interation with angle gear.
The angle gear is driven by the spline sleave wich is seperate peice .
The drive shaft acutally goes inside that and then seals itself on the tranny inside there.
I will see if I can get the sleave off and that will show in pics much better what I am trying to say
Re: (Chilled Man)
got it, thanks http://********************/smile/emthup.gif
someone explained this previously, I just couldn't beleive the axleshaft was skinny enough to slide through the hollow parts.
I think this should be added to the Master Information thread for reference purposes. http://********************/smile/emthup.gif
Discussion Starter · #13 ·
No problem
Any other AWD questions just ask .
I might slide under the XC tomorrow and get pics of the rest of it.
Discussion Starter · #18 ·
Re: Your AWD in Pictures :D (o2k)
Quote, originally posted by o2k »
Sweet pics! While you're at, any ideas on strengthening the angle gear?
I would be more concerned about upgrading the spline sleave first then the angle gear.
But make the both out of the same metal and use a thicker oil and change it often.
1 - 20 of 28 Posts
