I recently replaced the rear bushes on my LCAs (just the rear/big ones, rest looked and felt fine but those were gone). In doing that I didn't really find anything odd but after having my car aligned as well (not sure if the problem was there before aligning, matter of days in between) there is a defenite clunk in the suspension coming from the right hand side but ONLY if I drive onto a ramp/bump while at full left lock, so the left wheel bumps up first and only then the right wheel. Definite metal-metal sound. On "straight" bumps there aren't any weird noises.
Like I said I can't really find the problem. Where to pry some more? Drop links? Sway bar?
check the endlinks i guess.
Which bushing did you replace? inside ( subframe) or outside ( hub)?
Could have been more specific I guess, the front LCAs, the back (subframe side) bushings. So, the biggest ones. I'll check the endlinks. Just try to wiggle them around a bit I guess?
