1 - 9 of 9 Posts
Hello Swedespeed!
Located in Chester NY 10918
I’m going to start by saying I love this car, I’ve just run out of time to completely finish it.
It is a 1995 Yellow T-5R with a manual swap from a 94 non turbo. 177k but will go up slightly as I drive this daily, ODO works fine.
Let’s start with the good stuff.
Performance mods:
NA Cams
NA Throttle body
White injectors
16T Turbo
3” turbo back OBX exhaust
RIP Kit
IPD Sway bars
IPD Subframe bushing inserts with new bushings
IPD upper and lower engine mounts
SNABB intake manifold spacer
SNABB metal shifter bushings
Maintenance:
Everything has been done in the last 3,000 miles with new parts from FCP Euro Unless otherwise listed
Clutch replaced with 850R
Trans gear oil replaced with Volvo gear oil
Flywheel was balanced
Slave cylinder replaced
Power steering rack replaced with a Detroit Axle rebuild
Engine is from a 98 s70 – I borescoped it before replacing it with the transmission and the engine was spotless. I removed the oil pan and cleaned it completely out.
PCV box and hoses
Timing belt and water pump
Serp belt and tensioner
Oil changed with Liqui Molly and new filter
Engine mounts
Bilstein Struts New with unknown brand lowering springs
Subframe bushings
Delta Links (that was fun)
Spark plugs, wires, cap & rotor all Bosch
K&N Intake cone (autozone)
Brakes are over 50% so I never replaced them
Tires are 70-80% Continental Contiextremecontact DWS on 17” pegs
Body:
There are going to be a lot of unfortunatelys happening in this section…unfortunately…
My brother was driving this around for a couple months and unfortunately didn’t put his curb sensors on so he destroyed the front bumper. I have it but it is in pretty bad shape. Body guy told me unrepairable. Currently I have a junkyard black 850 bumper on it just to get around with it. I have a regular red bumper to go with as well.
The rear bumper was unfortunately ripped off by my dad in his RV in our driveway not making the turn wide enough.
The drivers quarter panel was unfortunately also hit in my parents driveway by my friends trucks hitch. It is repaired and ready for paint.
I’m looking for $5,500 or best offer. Please reasonable offers only. I would entertain a trade for a newer car that is daily drivable and unmolested that gets 25-30 mpg.
All that written up and no pictures? Did I miss the location while reading?
Looks like you answered my question with the pics.
1 - 9 of 9 Posts
