Car: 2002 S60. I wanted to add an aux port so I bought a Yatour YT-M06-VOLHU which plugs into the CD changer port on the back of the HU-613 and has an AUX port as well as an SD card slot and a USB port.
Once I got the console apart, installation was straight forward. The Yatour requires constant on power so I pulled power from the red wire that goes to the back of the stereo.
Reassembled the console and tested the Yatour. I put a bunch of songs on an SD card and the unit was recognized as a CD changer, played songs, and changed virtual CDs on command.
The problem came when I started the engine. I could hear a whine through the speakers that varied with engine speed. Oddly, it wasn't limited to when I was using the "CD changer." I disconnected the Yatour and the noise went away. Reconnected it and the noise came back.
There's no separate ground wire. Just the DIN plug and a wire for power.
Any thoughts?
Hello, can you explain how you connect filter and what of kind filter? Can you give me example or photo how you did it. Becouse i have same problem...
