Hey one of my headlamp bulbs went out and since they were kinda dim anyway I decided to put up an HID kit. They run on 35 watt and aparently the stock bulbs are 55 watt ,so technically its ok. Any problems I should expect from those xenon bulbs ? im getting the kit from eurosports, and have a guy there put it up for me. in case my warning light says smth weird when its done, any way to get rid of it ? I was also tryin to find out where i can get those xenon projector circles, to go around the reflector cones in the headlight. to go with the hid im putting in . Any shops around toronto maybe would have them ? any help is welcome, im not too big on this stuff
Your best bet is to do a search on the forum. Its been discussed many times. If you want projectors, your best bet is to swap out the entire headlamps themselves with xenon projectors from volvo. Beware though, they go for like a grand a piece.
Re: (Turb04S60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Turb04S60</b> »</i></TD></TR><TR><TD CLASS="quote">Your best bet is to do a search on the forum. Its been discussed many times. If you want projectors, your best bet is to swap out the entire headlamps themselves with xenon projectors from volvo. Beware though, they go for like a grand a piece. </TD></TR></TABLE><br>x2 what he said. The factory projector bi-xenon headlight housings are far from cheap. At least 1k a piece. <p>You will need to get warning cancellers. You can get them from <A HREF="http://www.sharphid.com" TARGET="_blank">http://www.sharphid.com</A><p>I'd recommend you just got with a 55w kit, but even still you'll need the warning canceler kit. At least I do. (running sharphid 55w single beam 5000k kit)
Re: (trebor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>trebor</b> »</i></TD></TR><TR><TD CLASS="quote"><br>x2 what he said. The factory projector bi-xenon headlight housings are far from cheap. At least 1k a piece. <p>You will need to get warning cancellers. You can get them from <A HREF="http://www.sharphid.com" TARGET="_blank">http://www.sharphid.com</A><p>I'd recommend you just got with a 55w kit, but even still you'll need the warning canceler kit. At least I do. (running sharphid 55w single beam 5000k kit)</TD></TR></TABLE><p>I run both the 55watt kit and the bulb out warning eliminator, with excellent results.
