1 - 6 of 6 Posts
Hello all!
So as the title states, will xc90 front calipers fit on these wheels. I have a set on calipers waiting but no time to actually test fit. I dont mind adding a small spacer if need be.
Thanks for any input!
Which XC90 calipers did you get? Did you get them off an XC90 with 17 or 18 inch wheels? V8 XC90 all had the larger brake set-up.
Most anything will fit under the 316mm setup off of earlier models and all 2.5t. 328mm dual piston setup from late should clear everything and I would suggest checking figment on the V8 336mm setup it may be too close to the barrel on wheels with stick on weights.
Thank you for the advice. They are 320mm rotors. No spacers needed then? Can anyone confirm?
They’re 316mm. There is a 320 kit but it was never on a xc90 and was super rare and expensive.
I have the same kit:
Retrofitted to my 2003. Clears even the lowest offset wheels
1 - 6 of 6 Posts
