1 - 2 of 2 Posts
VCDS Release 12.12.0 (x64): Generic OBD2
Mode 07: Pending emission related fault codes
Address 10 (Engine): 1 Fault Found:
P0089 - Valve for Fuel Metering (N290): Implausible Signal
ELM327 OBD Bluetooth scanner + OBD Check Torque shows:
P0089 - Transmission
Suction control valve stuck
Symptoms:
* engine struggles
* AFR rises to 17,8
* Lambda rises to 1,3
* RPM drops
* engine stalls
Volvo XC90 2007 r.; mileage: 74500 miles; fuel filter replaced, fuel preassure sensor replaced: http://forums.swedespeed.com/showth...3-Fuel-Pressure-Sensor-(G247)-repeating-fault
What could be the reason of my recent problems? Which part is faulty?
Moderator
Scan it with VIDA to get the more specific Volvo code. VIDA may also guide you to the proper fix. Could be the PEM
1 - 2 of 2 Posts
