XC70 Utility/Micro-RV Build Thread
2006 XC70 Utility/Micro RV Build
How It Started
I purchased this 2006 XC70 shortly after my S80 was totaled. I looked all over New England for 2006-2007 XC70s with black interiors, and ended up finding this one in Falmouth, MA with 169K on it. The initial inspections looked good, but not perfect. The car seemed to need a PCV service and a couple small interior repairs. I ended up buying the car and getting to work on getting everything running smooth. My plans for this car from day one have been a micro RV with off-road capability.
Current State
Now the car has 236K on it, and I've done quite a bit of work in that time.
Done so far:
What's Next?
Future Plans
I will slowly be working on this project, there is a lot of design that goes into this. I plan to have a cargo box for the emergency essentials and extra storage, I'm also going to be adding more skid plates / protection for off-road adventures. While working on this I will also be working on the Micro RV portion of the project, which includes running water, completely isolated electrical system (Until car starts, then it will begin charging off alternator), off-grid power capability (solar/wind), comfortable bed for one, a TV, and an electric cooler (Goes down to 30*F)
Below I have some 3D models / renders of the cargo box design and the Micro RV design. I originally designed this around a 240/740/940 however it is easily adapted to a P2 wagon. There will be seating for 3 people including the driver (left-most rear seat stays in). The major differences will be the lack of a wood seperator between the driving compartment and living area, and the bed will be on the floor with thicker padding.
Cargo box design, approx. 48 inches wide - Designed to hold a full size spare, portable toilet, and recovery gear.
Micro RV design
I will be adding more design information and pictures as time goes on, stay tuned.
How It Started
Current State
Done so far:
- All Maintenance Items
- Replaced Gas Door Hinge (Would flap around while cornering, did not latch)
- Replaced Haldex AOC Pump (AWD not working)
- GROM Bluetooth Audio Adapter
- IPD Skid Plate
- IPD Strut Bar Poly Bushing Kit
- IPD Subframe Bushing Inserts
- IPD Silicone Intercooler Tubing (regretted that)
- Steel Mesh Behind Upper Grill
- Full Front Suspension Refresh
- Full Cooling System Refresh
- Auxiliary Battery System with Isolator
- Communications Equipment (Ham Radio, CB, etc.)
- Volvo OEM 2" Receiver
- Custom Wood Cabinet in Rear Cargo Area (Micro RV)
- Custom Wood Bed Frame (Micro RV)
What's Next?
- Steel Mesh Covering Lower Radiator Opening
- Lower Control Arms - Done
- IPD Sway Bar End Links
- IPD DEM Cover
- IPD Rear Toe Rods
- Volvo Auxiliary Lighting Kit w/ Hella 500FF - Done
- Upgrade Front Bulbs w/ Hella High Performance Bulbs - Done
- Upgrade to Air Horn
- High Performance Brakes (Largest rotors I can fit in 16" wheels)
- Auxillary Transmission Cooler
- Clean or Replace Front Headlight Assemblies - Done
- Repair or Replace Headlight Washer High Pressure Pump - Done
- Front-Mount Receiver (Researching)
- LED Interior Lighting
- High Current Alternator
- Custom Front Bumper Skid Plate (1/4" Aluminum)
- Custom Rear Bumper Skid Plate (1/4" Aluminum)
- Custom Aluminum Receiver-Mounted Cargo Box (For full-size spare and recovery gear, also holds portable toilet)
- Larger Size On/Off-Road Tires
- Micro-RV Build (More information below)
Future Plans
Micro RV design
