XC60 T6 R ( Overheating only when engine RPM is over than idling level)
498 Views 3 Replies 2 Participants Last post by  Doba
2011 XC60 T6 R ( Overheating only when engine RPM is over than idling level)
Hey all,
For the past couple of months, my car has shown weird symptoms.
It has a habit of overheating when the RPM is above the normal idling level. When idling it will always be at 90 degrees celsius and whenever I touch the gas pedal, it will accelerate to reach around 100 - 105. However, whenever I drive it slowly it will go back to 90 - 93 degrees Celsius.
Therefore, last week I decided to fix this issue so this is what have done so far:
1- Changed the radiator with original Volvo parts.
2- Changed the thermostat and the water temperature sensor with the original Volvo parts.
3- Changed the water pump with original Volvo parts.
4- Changed the radiator cap with original Volvo parts.
5- Make sure that the air in the coolant system is gone.
6- The fan is going as normal.
7- there is no evidence of engine oil mixing with the coolant.
and unfortunately, the issue is still present.
I have uploaded a video in the following link describing how the temperature is rising.
Also a video of the water tank after releasing the gas pedal
If you have any idea what might cause this problem? please do not hesitate to let me know.
#update
The fan module have also been changed 2 months ago with OEM part but not volvo original parts.
Although the fan seems to be working just fine, currently, it's showing a (p0480) code which is referred to the (fan control module).
Font Screenshot Technology Terrestrial plant Number
Swap out the cheap module for a Gates Module. They are known to be the best 3rd party ones.
#Update
The head gasket is leaking exhaust into my coolant line.
There was no visible evidence whatsoever of mixing oil or leaking water into the engine.
However, after a deep investigation, this engine is leaking hot exhaust air into the coolant line.
