1 - 9 of 9 Posts
· Registered
Dear community,
As I mentioned in another thread, I jumped to Volvo less than a year ago, and fell in love with a 2010 xc60 T6 and to be honest experience has been very good. (now it's 80k miles)
Eventually I got the feared check engine yellow light, related with catalytic converter, (later I realized the alarm p042 was showing)
The main mechanic did deep cleaning of the oxygen sensors and cleared alarms.
After 2 or 3 hours of continuous operation I got the yellow light engine again,
the mechanic advice of the recurring alarm could imply replacing the catalytic converter.
So, I thought (at fourth alarm reset and reappear cycle) it was time for carefully checking the catalytic converter. So, I was remitted to the exhaust repair shop.
As Volvo fan I dedicated some hours to the investigation, and realized that information about catalytic converters for Volvo XC 60 is rather scarce. (XC 90 has more info)
So, to my knowledge the automakers are not interested in making catalytic converters, and they seem also not to be interested in distributing them either.
So again, you have to look forward to your own solution or hack.
Before replacing it, the exhaust repair shop offered me the option to make a deep cleaning.
which I approved before going into the definite replacement.
to my surprise, the mechanic told me that when disassembling, there was no grid inside the converter.
I got upset because I would like the former owner to notify this to me.
I moved forward with the filter replacement that it’s somewhat expensive.
when waiting the confirmation, I receive another call that telling me that the car had not only one but two catalytic converters, and the second one grid was present but useless, and to complete the repair man he needs to replace both filters.
So I’m an more confused than angry, because the two grids will increase my expense 2x, and I would like to know if the catalytic converter nearest to the engine is the most important one.
Note: in my country there’s no enforcement to keep catalytic converters optimal, given that the emissions test is OK. However, for the health of the car, and my environment I would not let it run without the grids.
I will upload some pictures for complementing the info.
I'd appreciate any feedback,
Thanks a lot.
Road surface Gesture Finger Wood Thigh
Fixture Gas Composite material Auto part Metal
· Registered
Maybe something's being lost in translation but on a T6 there's only one cat. On the NA 3.2 motors there's two.
· Registered
There's only 1 cat, and your picture above shows the front honey comb in the catalytic converter, I do see where someone cut the back of the converter open - so - what's getting lost in translation? There are 2 honey comb wafers in a catalytic converter. The first wafer converts HC and CO to H2O and CO2 using left over O2 in the exhaust. The second wafer deals with the nitrous oxide. So yes there are 2 wafers in the 1 converter - but you don't buy converter parts and "rebuild" them. You just replace the converter if it no longer converts - usually due to contamination or failure from overheating (a missfiring spark plug can cause a melted converter due to too much unburned fuel, but yours does not look melted ) And certainly many times a wafer will break up and blow into the rest of the exhaust system - the ceramic honeycombs are pretty fragile and break easily if the steel wool padding between the wafer and the metal can degrades and no longer cushion the wafer.
Parts pages below for converter and the rest of the exhaust.
Product Rectangle Font Slope Parallel
Font Rectangle Line Parallel Slope
Font Rectangle Terrestrial plant Number Screenshot
· Registered
Wow, thanks for the feedback
I must admit that the most I learn about catalytic converters, the most I realize I have to learn.
This time is difficult for me because due to my daily duty, I had to leave the car on the garage, not able to check what's really happening.
It's better to make decisions reasonable well informed, this time however I am not sure if the exhaust guy is confused or just trying to trick me on.
I do agree that the picture showing "the grid" looks good.
· Registered
· Registered
On my 2014 T6 I’ll get the code every once in awhile. Usually when the tank is 1/4 to empty. It’ll go away after a while. I’ve tried a few “CAT cleaners”. Some clear the code right away. Others take a tankful or more. I’m at 166k and recently got the MIL again but it went away next few drive cycles
1 - 9 of 9 Posts
