1 - 8 of 8 Posts
How do the tip covers install? You mention they just push over the original tips? Are there no screws or fasteners? If it just relies on a pressure fit I would be worried if they would fall off in a carwash.
I have seen some on aliexpress that are fastened with 3m body tape which doesn't make much sense with heat applications.
Thanks.....
Discussion Starter · #5 · (Edited)
Thanks.....
Yah no screws. There some kind of adhesive that you peel tape off and just push quad tips over the original. Yah I hope it holds up over time & threw winter and car washes. I like them a lot 😍that if the exhaust fumes start fade them I probably buy again in few years since they cost less $50 & redo 😁
https://www.aliexpress.com/item/329...expid=33e9064e-8437-4ffb-8cdd-2c049a0340c5-31
I like the black rubber protection goes good with other black redesign accents . Plus cover more of rear bumper as you can see in video. Does not scratch and look bad😡 like original was doing.
Thanks for posting this. I like the look of the exhaust tips. I ordered a set. They arrived in a week to Canada.
Here is a pic.
Here is a pic.
😍 Yah the fit perfect right over original exhaust tip and looks way better . 👍🏼
1 - 8 of 8 Posts
