1 - 8 of 8 Posts
All Prices are SHIPPED, PM me with questions.
1. C70 Rear Bumper Bar + Plastic Bracket 8611102 (New OEM) $85
2. OEM Ignition Wire Set (from 98 C70 125K) $15
3. C70 Rear Plastic Trim Pieces (needs paint) $20
4. V70R Bumper Air Guide 9169384 (New OEM) $12
5. X70 Front Door Seal RH Plastic Plug Piece 9159912 (Used OEM) $2
6. Front Window Guide Right 9187647 (Used) $5
7. Rear Bumper Exhaust Cut Out Trim Piece (Used) 9484490 $5
8. V70R Front Bumper Plastic Piece (Used / cracked) 9190025 $3
9. Various Fog Light Cables (Used) $5
10. Ash Tray (Used) $7
11. Front Passenger Door Rear View Mirror Triangle (Used) $3 SOLD
12. Fuel Rail 1270568 (New OEM, never used) $40
13. Windshield Washer Fluid Sensor 9133166 (Used) $10
14. Transmission Gear Shift Selector (used, broken plastic) $4
15. Fuse Box Cover (used) $4
16. Coin Tray (Used) $5
17. Passenger Front Door X70 Wiring Harness (Used) $8 SOLD
18. V70R Fog Lights RH / LH 8620253 / 8620252 x3 (Used) $30 SOLD
19. IPD Center Cap (Used) $7
20. X70 Stock Coil (Used) $10
21. X70 Sunroof Cable Guides (Used) 6817602 $4
22. Fuel Pressure Regulator from 98 V70 AWD (Used) $5
23. Gas Door / Rear Gate Switch (Used) $5
24. Fog Light Switch (Used) $5
25. X70 Wiper Arm Left (Used) $7
26. X70 Door Lock Actuator Right (New OEM) 8628226 $80
27. Strut Tower Nuts x6 948645 (New) $3 SOLD
28. Fog Light Grill Inserts LH + RH (New OEM) 9151510 / 9151512 $15 SOLD
29. X70 Window Control Switch (Used / For Parts) $5
30. X70 Coolant Reservoir with sensor (Used) $35 SOLD
31. Air Guide / Belly Pan for Volvo C70 all tabs in tact 8611392 (Used) $35 SOLD
32. Volvo Grill V70 S70 C70 1998 - 2000 Does not include clips (Used) $40
33. Campbell Radial Tire Chains $20
34. Blaupunkt Radio Head Unit Conversion Cable -Will fit any 240 from '85-'93 $20 SOLD
35. AFCO Racing Aluminum Tube Endlinks 4 tubes for sale 3/4" Diameter 11" Length $25
36. Passenger Door from 1998 V70 LOCAL PICKUP ONLY $50 SOLD
37. Passenger Door Lock Actuator $25
1. C70 Rear Bumper Bar + Plastic Bracket #8611102 (New OEM) $85
2. Volvo OEM Ignition Wire Set (from 98 C70 125K) $15
3. C70 Rear Plastic Trim Pieces (need paint) $20
Discussion Starter · #2 · (Edited)
1 - 8 of 8 Posts
