1 - 18 of 18 Posts
Just drove it from work to cousin's. Parked. 15 min later, car starts, dies immediately, gives Anti-Skid Warning. Wtf? Help!
Sent from a rotary-dial phone using Edna the Small Town Operator
Discussion Starter · #2 ·
Back on, CEL, anti-skid temprarily off, engine system service required showing. What the hell is going on?
hows the engine running? Rough?
Drove it two blocks. CEL gone, as are all messages. Running perfect. Bizarre.
something similar happened to me once... ended up being almost a dead battery.
What group do S60Rs take?
Apparently we need group 48 or 49, externally vented.
In the northeast, what's the best place to buy batteries from? I've been looking to do this myself, and have read interstate is the oem for us, but don't know best place to buy from
CostCo, Sam's or BJs, if they have them in stock. Mine didn't.
You can buy direct from an Interstate store if you have them locally.
I bought mine from Autozone with an online coupon and ended up saving about 25%.
Your high speed network was down. Immobilizer com between CEM and ECM was not possible and stater will operate but the immo function stops ECM when no security code is sent from CEM. The anti-skid message is a default DIM message when the Brake Control Module communication is lost. Could be low voltage, could be something else. Full code readout will let you know.
Or you put new battery in it and see if it does it again.
+1 on the battery. Happened to me with both of my '04 Rs that had the original Volvo batteries. Slightly different symptoms.. one car died completely while the other went into limp mode. Replaced batteries with Interstate brand and both cars were good as new.
Same thing here, car sat for a month and anti skid came up when I started it. Restarted and it was as good as new. Must've been the battery go low for so much sitting in the garage.
Discussion Starter · #14 ·
Thanks gents. Will check voltage today.
I would also suggest checking the alternator voltage if the car was able to start but died. I would lean more towards the battery but it is worth checking.
My battery was down to 100CCAs and was still somehow able to start and run. Probably a good idea to check it every couple of years. You may not notice an issue until it strands you somewheres.
LOL! Couldn't they have come up with a "Battery Low" message or something?
Mine was down lower than 100cca. I had advance auto recharge it for me. Battery seems to be good.. But I should probably get a replacement.
1 - 18 of 18 Posts
