Discussion Starter #1
I am in need of the pigtail (connector and wires) leading to the reverse light switch. I would like as much of the wires leading to the connector as possible.
Thank you!
Tim
If you have no luck here, I'm pretty sure it's the same connector used in a variety of places around the car (like fog lights), across multiple models. I'd unscrew the switch, take it to a junkyard with a few Volvos and start looking, you should find it in a few minutes.
Discussion Starter #3
Thanks for the tip on that. I was looking around my engine bay and I have an unused connector from the kickdown solenoid that used to attach to the automatic throttle cable. I switched to manual trans and put in a manual throttle cable, so that plug is unused now. I am going to check and see if that plug will in fact fit the reverse light switch, and I might be in business!
