Write up: S40 (MY2005) Headliner Removal and Repair
146K views 99 replies 32 participants last post by  Gregd
#1 · (Edited)
OK, for what it's worth, here is a pictorial of how it's done. It's not quite as image intensive as my other write ups because I was getting a bit frustrated. All you need is a philips head screwdriver and a small flathead.
This was how ratty the headliner started to look. Even push pins just didn't cut it..
1. Move both front seats all the way back and then recline the backsupport all the way too. Then remove the headrests from the rear seats. Close sunroof.
2. Disconnect battery.
3. Next order of business was to remove the overhead lighting console. Refer to my post on how to install the electro-chromatic mirror on the procedure. Sorry I'm too lazy to go through the whole process here. Click here.
4. Take the sun visors off by popping these covers. There are tabs on the sides so you need so pull them outwards at the bottom. You may not be able to take them completely off yet because the cable that supplies the vanity light is tucked inside the headliner and hot glued. So I just left them dangling until I got round to it later. Two philips screws hold this end down and one on the other side.
5. Pulled the A pillar covers out and then cut the single strap holding it on. The strap prevents the covers from flying out and smacking you in the eye in the event of airbag deployment. Cut this retaining strap at your own risk!!!!
6. The "IC Airbag" cover hides a Philips screw that holds the cover to the B pillar. I didn't take the cover off because it wouldn't budge and I could get the headliner off with it still attached. I want to know how to take this off though.
7. Next three tabs in the rear need to be turned 90 degrees and pulled off. If they don't turn clockwise, try turning them anti-clockwise.
8. The rear light cluster is pulled straight down and then unplugged.
9. Sunroof trim. Just pull it out. See the sunvisor dangling by its wire in the background?
10. The "Oh Sh!t" handles have a small tab covering the screws. Use a small flathead screwdriver to pop the cover and then unscrew it. Then pull all the weather seals around the tops of the doors. No need to pull it all the way to the bottom, just the tops.
10a. Pull the C pillar covers off the same way you did the A pillars. There are retaining straps here too.
11. Finally with all the anchors undone, you can pull the headliner down, not too hard though. There are still cables hot glued all over the place.
12. Here is the sunvisor power supply for the vanity mirror light. Once unplugged, you can remove the sunvisors completely. Unplug that and the rear overhead brake light after you have released the cables from their hotglue bondages.
13. Unplug the rear brake light.
14. This was how I managed to squeeze the headliner out. No need to remove the doors or seats. But I was very close to giving up and cutting the headliner in half.
Turn it sideways and use the full diagonal of the passenger door and you will be able to get the thing out. You will need to bend the headliner slightly but no folding necessary.
15. Voila!! Headliner off! Then I fixed myself a drink.
16. With the headliner off, I took a few pictures because I was surprised the sunroof was drained at all four corners.
Left Front
Left Rear
Right Rear
Left Rear
17. Side curtain air bag is one long piece all the way to the back.
18. Brushing the dry-rotted sponge backing only requires a stiff bristle brush. I used a dishwashing brush by OXO. Use long firm strokes, almost like scrubbing the floor. There is no risk of scrubbing through the headliner backing.
19. Done
That's it for tonight folks. Hope these photos are archived in swedespeed servers.
Next..up
The reapplication of the new headliner.
Nice writeup!
I know how ya feel about removing the headliner once it isn't attached. It was super frustrating getting it out and took a while.
Excited to see the finished result.
Let's just say I'm not much help there. It took me like 4 hours to get it out, and 6+ to get it back in and it doesn't slide properly. I don't use my sunroof that much so it doesn't bother me.
What really sucks is I used a different adhesive on the sunroof cover because I ran out of the other adhesive, and it failed literally 2-3 days later. So the middle piece of my sunroof doesn't have material on it and looks bad.Whenever people ride in my car I just open the sunroof, lol.
For all the work you've done you should mix it up a bit, but an OEM-like headliner material would be the simplest/best material to use since it is made to be lightweight and last.:)
#13 ·
I drove without my headliner in for like 3 weeks, lol.
I know how that is with pot holes, on my way back from Seattle a few weeks back I blew out a tire. :( $800 later and I've got new tires...
Thanks! The thread has been linked in the sticky. As for the photos, no they are not archived in the SS servers. That function did become available with the new forum software, but for some reason it doesn't work and the admins haven't indicated it will be enabled. If you plan to take the links down, please advise as it will break the post.
#17 · (Edited)
1. Before starting the adhesive procedure, fold the headliner in half all the way length-wise. Then use tacks to hold it down in the center while you measure to see if you have enough material to go to the edges. I was concerned because my material is only 54 inches wide and cutting it real close. The rear of the headliner requires the most fabric so start there. Despite doing this, I came up a little short on the rear corner.
2. Start spraying the adhesive and work on small sections. Don't get too ambitious because the glue is extremely strong and working the material into the depressions and compound curves takes a lot of finesse. I messed up in a few spots around where the grab handles are. You can see creases from my amateurish effort.
3. Do not precut the material to the exact size yet because you may want extra material to fold over the edges. That way it would be a little more difficult for the headliner material to start unraveling and fraying at the edges in the course of time. Additionally, I don't like being able to see the sponge backing through the front windshield glass if you cut it right along the edges.
4. Once you have finished with the entire liner, flip it around and leave about 1.5 inches beyond the edges and cut around the headliner. Then spray the glue and fold over.
5. Let it stand to dry before cutting out the holes.
#18 ·
2. Start spraying the adhesive and work on small sections. Don't get too ambitious because the glue is extremely strong and working the material into the depressions and compound curves take a lot of finesse. I messed up in a few spots around where the grab handles are. You can see creases from my amateur effort.
+15697813. When I was doing my headliner it was a freakin' nightmare. Let's just say I was a bit over zealous when it came to spraying adhesive.
#19 · (Edited)
The sliding sun shade needs to be removed in order to reupholster it. (thank you Kyle for the instructions)
The sunroof glass has to be removed. Hopefully at this juncture, you have the sunroof completely closed. Otherwise you may need to reconnect the battery and close the sunroof glass.
1. There are two T20 bolts on each side of the sunroof glass. The accordion privacy louvers need to come off. Remove by pulling them at their anchor points. Do not yank anywhere else or you may tear it like I did. :(
2. Once off, you can see the two T20 bolts. Unscrew them all while supporting the glass.
3. Take the glass off from the top and set it down someplace where you won't step on it.
4. Pull the sunshade forward and look through the top. There are a total of 4 T20 screws that hold it on the track. Unscrew the front two.
5. Then take the track guides off so you don't lose it.
6. Pull the shade forward some more to access the rear bolts.
7. The shade comes completely off. No hacksawing required! :)
8. The plastic piece comes off by pushing all of these tabs. Then the entire liner can be ripped off right down to the metal backing plate.
#20 · (Edited)
When upholstering the sun shade, leave extra fabric at the edges to fold over, just like the headliner. Cut a narrow strip out from the middle of the ventilation holes. Do not cut to the edge otherwise you will see ugly edges of your headliner material peeking out from under the plastic piece.
I also found it advantageous to leave some extra material around cutouts so they act as vibration dampeners. The clips also hold a little more securely.
Back and front after cutting out the sunroof hole
The finished result, a factory look.
Before:
After:
When light hits it a certain way, the headliner looks lumpy, but I'm very happy with the result and the amount of money I spent on this project.
Total Cost:
$48 for 3 yards of headliner fabric at Jo-Ann's
$12 for 2 cans of headliner adhesive spray at AutoZone
$0 for lots of elbow grease
Dealership estimate: $900
Upholstery shop: $300-$400
Peace of mind knowing it was done right and all pieces/screws are in place: Priceless!
_____The End____
#22 · (Edited)
Sorry to bring back such an old thread. I just wanted to say, when removing the A-pillars, you don't have to cut the retaining straps. They slide in/out of the A-pillar panel. It's a paint to get them back in, but a peace of mind knowing that the panel won't fly across the car in case of airbag deployment. I can post a picture of what I'm talking about later.
#23 ·
Here's how you can easily unhook the retaining straps to the A-pillars, so that they can be reattached later.
No worries of panels flying about the cabin upon airbag deployment :)
#24 ·
thanks MyNameIdeasWereTaken for bumping a old thread lol & thanks aldebaran for the d.i.y. have to fix my falling sunshade
#25 ·
I followed this procedure yesterday and it was pretty difficult to get the headliner out without bending it.
I'm not sure if after putting a new foam and fabric the few bends I made will no be visible, there are 2 lines ( like if it broke ) on the foam/fiberglass.
I also scratched a bit the waterfall console. It would have helped to put the car on D before unplugging the batter as well.
For putting it back in, I'm removing the console. I'm pretty sure that it will come in without having to bend it if I do so.
http://forums.swedespeed.com/showthread.php?167046-How-to-Videos
#26 ·
Yeah, shift nob in a downward position really helps. Never thought about removing the console, but that would probably make this job effortless then!
#27 · (Edited)
After some Spring Storm - I'm getting more E-mail about this Issue : Sticky Area for some Reason seems Hard to locate to some .
___Photobucket has Limited the Amount of Information - Clearly to be Displayed - No Description Area Currently as Before .
______( FELL FREE to Write Me as many Others have and get Needed Details on Fixing )
http://s261.photobucket.com/user/EngTech1/slideshow/Sunroof%20%20Maintenance%20%20and%20%20Leak%20Repair
I'll only Post the Important Information which to : FIX YOUR VOLVO for LIFE
so It doesn't Cost You $500.00-$1200 Dollars ! :beer:
owns 2009 VOLVO V70 3.2S
#29 ·
I'm not sure where aldebaran bought his headliner fabric, but I know that Joann's Fabric carried some headliner fabrics back when I was redoing mine. Hope this helps.
#30 ·
This! I'm about to re-do mine (something different this time around) and got the foam backed fabric from Joaan's as well.
#34 ·
The service manual says to remove the windshield first and then take the headliner out from there. Well, I already got it out through the passenger door but had to bend it pretty hard. Car has a crack in the windshield already so I'm taking the glass out and replacing the headliner through there before putting in a new windshield to kill two birds with one stone so to speak. Taking the board to an uphostery shop who will recover it for $90.
#35 ·
Is anyone aware of any differences in the S60R's install as compared to this?
I have a SUPER annoying rattle just behind my head that I want to get some foam on or figure out what it is. Will be following this closely.
Thanks for the writeup and sorry for the ancient thread bump :).
