Re: Worn Brake Pad Indicator Noise & Front Vibration (kinnup6)
Most brake pads have a wear indicator of sorts. Take the wheel off and look at the brake pad (no need to remove any other components). If you can't make out the groove down the center of the pad, the pads are basically shot and the noise could well be the wear indicator. I'd be surprised if you wore out your pads in 17k miles.
If the groove still exists (indicating some brake life left), the noise could be something else, like a wheel bearing if it's speed-dependent. Does the noise change when you turn the car left or right at speed?
