Lesky said:
when the dots on the timing gears are closest to each other, does that mean cylinder one is at TDC?
Yes.
This is all from memory, but you don't need to stress too hard about the distributor drive gear, there's a mark on the distributor that indicates TDC #1. It might not be at the same place as this pic, but there will be a mark like this somewhere.
So here's what you do:
-Set engine to TDC #1
-Drop drive gear in
-Install distributor in desired orientation of the body (you don't have to bolt it down) Basically you want it where the vacuum housing or clips or whatever won't hit the engine while adjusting timing.
-Look at where the rotor is pointing relative to the mark on the distributor body.
-Note how far the rotor would need to rotate to line up with the mark.
-Remove distributor
-Lift drive gear and rotate it approximately how far the rotor was off.
-Repeat if needed to get the rotor in the ballpark of pointing at the mark. Obviously you can't adjust less than a single tooth so it'll never be quite perfect, that's what the timing adjustment is for.
-Bolt down distributor, then loosen the adjusting clamp and rotate the distributor body to line the mark up with the rotor.
-That mark will also line up with the hole for the #1 spark plug wire, so make sure you get the plug wires in right too.
If the rotor is pointing at that mark when the engine is at TDC then the engine will start enough to set timing with it running.
I'm 95% sure that the quarter windows come out and go in just like the rear window.
As for the chrome gutter trim, I have never had success getting that off (I always bend it up), but obviously there are tricks. Might want to talk to a classic car restoration shop and ask if they know the tricks, maybe someone would come by and do it for you for a case of brew.
