1 - 20 of 74 Posts
Discussion Starter #1 (Edited)
Hello Swedespeed. I purchased my 164 back in 2009 but it is only recently that I am able to really dig into it. I'll start with a short intro about the car and my current plans on what I'd like to do with it. Then, I'll post a few recent pictures. My plan here is to pseudo document my work on the car to get some ideas, help with trouble shooting, and frankly just to talk about working on old Volvos. I felt a 164 thread was appropriate to balance out all the 140 builds.
The car:
I'm working on a 3-speed, 3.31 rear 1973 164E that's mostly original and, surprisingly, rather well documented. The original owner bought and drove the car until 2008 with occasional stints in storage. I have a lot of info regarding what the first owner did to the car. The major items that were done were complete underseal from new, new upholstery front and back, and rear wheel well rust repair. In 2008, the second owner bought it and l tucked it away in his garage. He had it for only about a year when I bought it in 2009. Since then, I've driven it about 10,000 miles, stuck it in storage for 3 years, and driven/dragged it across the country. I've blown the transmission and original fiber timing gear in the process and had my fair share of D-jet issues. The car has about 105,000 miles on it.
My plans:
I want to do a complete restoration of the car as best as I can and modify a few things here and there. I'd like to do most of the work myself, too. If you haven't already seen it, I take a lot of inspiration from John H's 164 build thread on the Volvo Owners Club forum out of the UK (see link). Currently, my plan is to freshen up the engine and suspension, drive it for a bit while the weather is still nice, then take it back into the garage for the resto work. Detroit has a lot of cruises that I hope I can get the car out to before starting the major resto items. Regarding the restoration, I will keep the look of the car mostly the same but I'll put my own touch on a few things (Mega Squirt conversion and more sporty styling). It'll be full road trim and I plan to keep the Volvo powertrain as much as possible. No turbos or blowers under the hood. I expect this will take something like 2-3 years of hard work and lots of my paychecks.
I've had the transmission rebuilt since blowing it a few years ago. I'll be sticking with the 3-speed for a little while, at least.
John H's 164 build: http://www.volvoforums.org.uk/showthread.php?t=60815
Also, I would like to:
Design my own Type R ish gauge cluster (perhaps Speedhut? VDO?)
Add front (and maybe rear?) spoiler(s)
Add Virgos (I have a nice set already)
Swap D-jet for Mega Squirt (lots of info from one of the 140 threads, plus D-jet stuff is sooooo scarce). Looking at an MSII kit.
Lower ride height
Replace all suspension bushings and ball joints
Respray the car the same green color
Go back to leather seats. Currently I have cloth seats (non-original). I'll post a photo soon.
Add fog lights (have some OE fogs that need some TLC)
Maybe tweak bumpers
Delete some OEM chrome trim
Retrofit R-12 A/C to R-134a
Here are some photos of the car to give you an idea of what I am working with.
Discussion Starter #2
I've started poking at the engine. I want to pull it, completely disassemble it, check everything out, replace/clean what's necessary, and then rebuild it. This might sound silly as a "just for kicks" exercise, but let me give some background.
Like I mentioned, I blew the original fiber gear. I haven't quite put my finger on it, but I think the fiber gear bits were able to get into the sump. Since then, I've been getting rather large chunks of stuff draining out with the oil (some just small enough to fit through the 1 inch drain plug!). I started seeing them 3 years ago and if memory serves they looked metallic. My initial thoughts were either a piston skirt or pieces from the block. I didn't test with a magnet at the time and I didn't keep them. This was in between undergrad and graduate school, so my priorities were focused in different directions. At the time, I thought my engine was breaking apart.
Fast forward 3 years. Draining the oil last week yielded no less "chunks" of something (photo). A simple magnetic test shows that these bits are non-ferrous but, as a results, I want to pull the engine and freshen it up. Furthermore, I've got 40 year old bearings, rings, fouling, and potential "silting up" in the #6 cylinder. Why not bring everything up to snuff? I want to drive the snot out of this car once I'm finished. This is probably more "because I want to" than is really necessary, I'll admit.
Progress so far: I've started pulling the D-jet harness, fuel rail, injectors, manifolds, drive shaft, radiator, and aux items on the serp belts. I'll pull the ATF cooler once I source some caps to plug up the supply/return fittings. Also, I'm waiting to borrow a cherry picker and buy a load leveler. So, things have stalled at the momemt.
Pics:
These are tiny debris but this is what I'm seeing lately (non-ferrous per magnet check)
Where things are at regarding engine pulling: pulled cables, manifolds, steering pump, A/C compressor, alternator, fuel rail, and injectors.
Dropped exhaust. I want to clean up down pipes and paint with high temp paint. I had to cut the pipe that goes over the rear axle to drop the exhaust.
Injectors:
So, I'm as ignorant as it comes regarding storing injectors for any length of time. I've read things from "spray them down with penetrating oil" to just "put them in a ziploc with desicant packs" when it comes to storing. I'm an engineer by profession, and to me it seems that injectors live happily when there is gasoline in them. I decided that I would store them with the pintles submerged (to prevent corrosion from MI humid air) and with gas in the rail lines. I then sealed these in mason jars with the tips of the injectors resting on the o-ring seals (keeps pintles off of bottom of mason jars while still submerged). I hope it works otherwise I'll be spending lots of money buying new injectors. Not the best photo, but pintles are submerged in old, treated gas (w/ stable) while short fuel rail tubes are also filled with gasoline. Though, I did not do anything to protect the electrical contacts from exposure to gasoline.
Storing them in stabilized gas probably won't hurt. I don't know whether the Bosch injectors have any internal rubber bits that would dry and shrink, I am thinking not; but, the storage in gas probably doesn't hurt. The solenoid coil should be sealed so you should not have an issue with the electrical parts. They definitely need to be in a sealed container of some sort to deal with dust and humidity.
It looks like you have already had to deal with this on one of the injectors; but, you should plan for replacement of the short stubs of 5/16 fuel line that connect the injectors to the distribution rail. The stubs age and can pop off the end of the injector when pressurized. The one injector in the bottle has a cheese grater style hose clamp. Replace them with proper banded clamps that do not chew up the hose. You can go fancy stainless steel or get perfectly serviceable ones from most auto parts store at a pretty low price. You will of course, be changing the three rubber seals and rings that the injectors fit into in their respective holders. Consider shipping the injectors to RC Engineering or some other FI specialists to have the injectors cleaned and flow tested.
If you are doing the MS II conversion, be aware that there is a bit of misinformation going around about the Bosch 0 280 150 038 injector. The flow rates as published by Bosch are 384.3 gm/min at 3 Bar which is about 48.2 lb/hr @43.5 psi. When I did my conversion, there were some threads around which discussed flow rates that were much lower. Can create a bit of an issue when setting up MS!
Discussion Starter #7
Indeed, the hose clamps will be new when I do the re-install. I did some reading about getting the injectors flow tested. I found a few places but that will wait until I figure out what, if any, internals for the B30 I need. I have read your post about the discrepancy in flow rates. I will revisit once I'm ready for EFI work.
Discussion Starter #8
No physical progress. However, things are coming together. I am able to borrow a colleagues engine hoist and load leveler for the B30 extraction. Will receive both tomorrow. I hope to pull the engine and transmission over the weekend. Will post photos afterwards.
Discussion Starter #11 (Edited)
I am not sure about the rims. I'll find out and post. However, see below for a better shot of the rims.
I have Virgos for it as well, but the ones on it now I also really like. They might be KMGs and based on the white colored rust I think they're aluminum.
Discussion Starter #12
LloydDobler, thanks for the link. I am always glad to get some more info regarding MegaSquirt.
Discussion Starter #13
Finally, some progress.
This is my first engine pull, so I've been busy gathering the items I needed to do the job. I was able to borrow a hoist and scored a cheap load leveler. Then, sourcing bolts was way more difficult than I hoped for. I used grade 8 bolts to mount the load leveler (overkill, honestly based on proof strength) and Home Depot/Lowe's only stock limited sizes above about 1/2". Also, since I was using a load leveler initially designed for V8s, I had to tweak it a little because the B30 is so long.
Anyway, the B30 green book shows only 3 mounting locations for pulling the engine. One is just behind the oil filter and is a 5/8-11 thread. The hole sits just above the coolant drain plug.
The other two lifting locations double as mounts for the A/C compressor bracket. These holes are 7/16 (I think) UNC. I forgot my notebook in the garage. I can confirm if someone wants to know. The mounting holes are on the driver's side of the block.
Here everything is mounted up.
Whoops, there it is.
Somethings I learned after doing this:
The garage most likely isn't tall enough. I had to lower my jack stands twice and shorten the leveler chains.
Remove the rocker cover. The leveler chains will mush it up pretty bad.
The leveler chain will tear up the threads on one or two manifold studs.
Use a load leveler. This would have been hell without it.
The green book says to remove the dip stick and cooler lines from the BW35 before pulling the engine. This is impossible and not necessary.
After getting the engine/trans pulled out, I then removed the transmission and mounted the block on my engine stand. The green book isn't detailed about how to removed the torque converter mounting bolts but there is an access cover that drops off the bottom of the block just in front of the transmission. Then, you need a buddy to hold a breaker bar on the timing pulley while you remove the torque converter bolts from the flywheel.
Here it is mounted on my stand. My torque converter, for some reason, is blue. Also, a nice shot of the rims I have.
Next steps are to disassemble the engine completely, clean everything up, and see what needs attention. Also, I plan to clean out all the bits of fiber timing gear still lurking around in the sump.
Until next time.
Discussion Starter #16 (Edited)
This was a busy week working on my engine. I managed to get the whole thing torn down. The extent of remaining timing gear debris was substantial. When it originally broke, I had it replaced by a Volvo dealership. This is what was leftover (minus pieces throughout bottom end) in the oil pan.
While tearing down the block, I had to stop and think about how to remove the valve lifters. The green book specifies a special tool for this, which is near impossible to find. Anyway, it turns out you can remove the cam without removing the lifters. The lifters can be removed afterwards. Here's how I did it. The green book does not have a procedure for removing the cam.
Take the cam timing gear off as well as the cam thrust plate. You should be able to rotate the cam back and forth by hand. Rotate the cam back and forth until you can separate the helical gear mesh between the cam and the distributor shaft. You should be able to remove the cam this far.
Next, you have to remove the distributor shaft. This is hard to do unless you are able to separate the helical gear mesh. Remove the distributor clamp and then you should be able to remove the distributor shaft. Next, carefully slide out the cam.
Distributor clamp
a
Distributor shaft
From here, the valve lifters can be eased out of the block by using something soft to tap them out. I used a rubber mallet and some wood to tap them out from the bottom of the block. Worked great. Reinstalling them won't be so easy.
Here's a shot of the internals (before removing cam and lifters)
I must admit that I am not convinced that there is a difference between laying the crank down and standing it upright for storage. The crank weighs approximately 75 lbs and the center 3 journals are really all that isn't supported in this position. Hardened steel should have no problem remaining in the elastic region under this amount of loading in bending. Warping implies plastic (permanent) deformation. Regardless, the crank can be straightened for minimal costs.
I'm very impressed. Of course that's mostly because I was "too scared" to even trying pulling the head off my 164E by myself. Thankfully, I was finally able to find some 70 year old guy with B30 experience to come help me do it this past weekend. I look forward to tracking your progress and your car looks very nice.
Discussion Starter #19
This is my first engine pull and things are easier than I expected. Just dive in. IC engines are fairly forgiving on most things. Hopefully pulling the head gave you the "itch" to keep going!
Discussion Starter #20
Can someone explain what exactly is measured when "decking" a block? I know it's some measure of the height of the head mating surface. But where is this typically measured from?
Also, I've been hearing things like blocks warp due to heat cycling. Has someone experience this before? I find this also hard to believe, since thermal expansion coefficients of cast iron are well known.
1 - 20 of 74 Posts
