Couple of issues to address that I hope others can help me sort out. Car is a '65 122 manual.
Not sure what is happening with my lights. My headlights use to only turn on when I pressed on the floor high beam button. However now they don't work at all and my rear lights and side marker lights are on all the time. I am unable to turn them off. I understand the low beam headlights are wired directly to the switch on the dash, no relay required. What about the rear lights and side marker lights?
I discovered the top fuse in the box on the firewall (contains 4 fuses) is burnt out. It is a short fuse and the label indicates it operates the wipers, but the wipers are working fine. Where would I get a short fuse. I have seen the longer ones but not the little short stubies. I am beginning to think a PO has really messed with the wiring.
Where is the temperature/thermostat located in the cooling system that gives the reading on the dash. Again, mine is not working but I have checked the temp at the rad using a temperature laser and it never reads higher than 82C or 180F. I would like to get this working as well but don't know where the thermostat is located? Is the wiring direct to the dash as well or is a relay involved.
Lots going on to sort out. On the plus side the car drives very nicely (knock on wood).
Marcus
Marcus
