1 - 17 of 17 Posts
Does anybody know how to make the wiper to wipe my windshield smoothly? Right now it is very rough as the window and wiper contact is not full and that the wiper jumps around just as if the window is dry but then it's raining hard. Any suggestions?
Thanks guys
You might try changing the wipers, not just the single blades. Anco Premium work perfectly, in my opinion. They are always smooth and work really well for up to a year or so. The wipers are really easy to change as well.
-Drew
quote:
Thanks guys
Go to your Retailer and they will change the blades, under warranty.
Yannis
Mr. T5 , Try turning the wipers on and when they are straight up vertically turn the key to the off position so they stay up. Then at the base of the arm of the wiper push the arm down so it is putting tension on the arm then let go. This slightly bends the arm in to create more pressure on the blade.
It's an old Volvo trick.
Good Luck
Re: (CAL)
Like Mr.T5, I started having problems with my wipers. Before I say anything else, I have researched the Swedespeed site and found nothing that talks specifically about poor wiper performance in cold temps. So I need some help:
I'm driving home last night in the snow. Temp is 27. Everything is freezing to the windshield before the blades can clear it. I've got the defrost on full blast. Had to pull over, physically clear the windshield and wiper blades. I noticed the wiper "arm" that holds the blade is completely frozen. So I knock out the ice, flex it the blade a few times and hop back in. No luck
I kept getting the splotchiness as the clean blades would only clear off small portions of the swept area. Pulled over 2 more times, but nothing helped.
I know many people have had complaints re: the windshield wipers on various Volvo models, but before I take it to the dealer for a warranty replacement, is there anything anyone can suggest to combat the apparent "frozen" wiper arm problem? The blades work perfectly otherwise (above 30 F).
Wipere blades are supposed to be done under warranty?
I just paid $25 to have mine changed by the dealer, and now they are chattering/skipping like crazy. I also had to pay for my oil change as well, even though I was at the 22,500 mile mark (see my other post on this topic).
Re: (ChicagoT5)
Quote, originally posted by ChicagoT5 »
Yes, they are supposed to if they're bad which ALL Volvo blades seem to be
There is a trick that seems to help, hthe dealer check the angle of the wiper arms.
They do actually have a tool for this.
Most Volvo wiper arms are a bit out of spec and they will chatter and squeak.
They just did my S60 and so far, so good. http://********************/smile/emthup.gif
Today I'm driving a loaner S40 with the new flat blades, what a joke. Car has 1000 miles and the wipers were so bad I had to stop every few minutes and try to clean the blades.
Went home and glass polished the windshield, helped a lot for the cleaning of the glass but the left one still squeaked like mad. http://********************/smile/emthdown.gifPOS, these new blades.
I have had other 04 loaners with the same blades and they ALL were crap.
JRL
Re: (JRL)
My S60 has the 'chatter' problem on the driver's side. It seems to come and go, I can't pin down what weather conditions make it come and go. Nice to hear that there might be an angle adjustment the dealer can do to fix it.
On a side note, I recently installed a wannabe flat-blade from Canadian Tire ($25CDN), it works well, seems better at high-speed and didn't freeze stiff with some recent ice-raing like my stock blade did on the passenger. I seems to chatter less often. I also like that I can see the red security LED from in front of the car more easily than with the big bulky stock blade. On the other hand, I think using flat blades with stock non-flatblade arms looks a bit funny though. Just can't win
field172.
My new wipers seems to chatter at 27F or colder, which someone also posted. Really pisses me off that OEM Volvo wipers don't work in the cold.
Re: (Mr. T5)
I would sugest a little car wax on the windshield it will help out a bit. also I was just rescently driving through Austria in a snow blizzard and the blades were freezing up, not on the wind shield but on the coverage of the windshield, the front windhield defrost on max tend to work well after a few secs
Re: (ChicagoT5)
With older cars, I can "blip" the wiper stalk to get the wipers to stop just above the windshield. This way it gets some of the heat from the windshield (defoggers), reduces ice accumulation, etc. However I cannot do that with the electronically-controlled wipers in modern cars.
Freddy
Re: (garbergtsi)
Quote, originally posted by garbergtsi »
Wiper blades and NOT covered under the 50k/4yr warranty!!!!
thats just crazy!!!
Technically not after 12K, but since mine seem to go bad on my S60AWD every couple of months they (the dealer) just keeps on replacing them
After they had the angle adjusted they work better, but not perfectly
1 - 17 of 17 Posts
