1 - 6 of 6 Posts
What is the cure for intermittent wipers? They turn ON -- OK... They turn OFF, no go, most of the time, unless you shut off the engine. Remedy: Clean the switch, change the relay, or what?
Re: (DVolvoguy777)
I replaced the Relay and get the same results... Now, after checking with the manual, MAYBE I should check the ground?
Haynes Volvo book for 1976-1993 Volvo Series 240 shows electrical diagram at 12-35. Does anyone know where the ground connection (H) black wire connects with the body?
Re: (Camyman)
The wiper motor has several wires conneted to it. Is the ground the wire the one that connects separately to the wiper body? (Can you tell that I have only passed basic electricity?)
1 - 6 of 6 Posts
