winter tires for xc7o
1510 Views 7 Replies 4 Participants Last post by  beavenx5
I have a perfect set of Nokian hakkepellitta 205-55 R16 barely 3 months old from my SAAB 9-5 . Would these fit the Volvo 16" alloy rims of the 2008/9 XC70?. Does Volvo have alternately in accessories metal rims for thatXc70 that these tires could fit onto?
1 - 8 of 8 Posts
Just found older message,not possible?
I found a message a few months old,which describes the tires for OEM 16" rims as 215.55R16. I guess the tires i have are too small in diameter. Can the odometer be calibrated to address a smaller size as 205.55R16? Any way around this so as to use the perfectly good and expensive Nokians? Of interest ,would they fit a smaller Volvo like the v50?
Apologies,OEM should read 215.65R16
Correction
Re: winter tires for xc7o (mechonit)
Isn't the stock tire size for the XC70 215/65R16? I know you want to use the good snows off of your Saab, but I think they are too small, especially if I am right about the 65-series OEM size.
I have 215/55R17 snow tires on my '09 S80, and THOSE tires look a little small for the car, so I would image your 205/55R16s under the raised body of the XC70 would really be too small.
Re: Apologies,OEM should read 215.65R16 (mechonit)
Quote, originally posted by mechonit »
Correction
You know you can edit your own post later just by clicking the magic Edit button next to the Reply button?
If you just go to this link, and punch in both sets of tires, (assuming the narrower tire even fits on a 16 inch Volvo rim or steel wheel that you get - 10 mm isn't a lot) you'll see that the diamter of the two would be off by about 8%. That's way too much. A few percent at the most would be acceptable.
http://www.1010tires.com/tiresizecalculator.asp
Stock Tire - 215/65R16 Tire1 - 205/55R16
Whereas if you put in the stock 16 and the stock 17 (235/55 17) you'll see there's less than 1%.
Thanks for the responses.
I appreciated the replies. A friend plans to try the tires and rims on his Chevy. The 9-5 rims fitted a number of GM cars including the older Saturn L series and i am told the Caddy CTS. i will simply start from scratch with all I need with the Xc70
Re: Thanks for the responses. (mechonit)
I got lucky last fall and got 4 almost new Neptune 17"X7" Volvo OEM mags from a 2008 XC90. I got them on e-bay from a tire shop in California and paid $175+$80S&H for the 4 of them. I had to get hubcentric rings also ($12) since the hubs on the XC70 are a little smaller than the XC90 ones.
Maybe you will find a good deal also if you are patient. You have plenty of time before the next snow fall............................I hope...
1 - 8 of 8 Posts
