What do you guys do with your meth systems now that its starting to really get cold? I don't drive my car in the snow and did not know if I need to do anything to it for winter storage meth wise thanks.
Meth is used for deicer, so if you have a proper mix on it (top it out with the blue...) then I would think you would be fine. If you are running mostly water, I'd purge it and fill with "blue water" or a strong meth mix, just to make sure.
I run the premixed boost juice or the devils own blend is what I have in it right now.
if you run anything above 27% meth mixture or so you're good from -20 degrees F and below.
Thanks man so I'm just gunna let it sit over the winter and start it up once a month and wait till spring. Hybrid turbo, custom parts and new tune :D
