1 - 12 of 12 Posts
Ok I'm tired of looking at them on the shelf and want to put them on already, I have the Cfwerks winglets with a set of brackets but for the life of me I can't figure out how these brackets actually mount. Does anyone have a picture of them mounted so I can see the orientation of the bracket?
Any help appreciated.
The bracket from Volvo looks like #19 in the above diagram. If you're going to bend your brackets, this is the shape you're going for.
yeah bending these without some serious help isn't happening, wonder if volvo sells those seperately.
OP - Have you considered contacting CF Werks for some assistance?
I assume the brackets you have pictured came with the winglets - no?
Just do what aldebaran said. I had to bend mine too. I used bench vice and pulled it by hand to get the bend I needed.
I have I'm awaiting a response.
That helps a lot thanks.
Hi Psy,
The brackets we send with the winglets are meant to be straight, you will need to bend them in a vice, or bench table + hammer to the correct angle. Each bumper is slightly different due to sagging, or otherwise, so we leave it up to the customer to make the last bend to ensure fitment is perfect. They brackets are aluminum, so you will have no problems manipulating them with the right tools.
Any questions, let me know
Henry
Ahh ok then thanks for the reply.
Hi Psy,
Henry
1 - 12 of 12 Posts
