1 - 2 of 2 Posts
The drivers side windshield washer on my SR has lost almost all of its pressure. The reservoir was dry for near a month, the problem started as soon as I filled it. Has any one seen this issue before?
Probably sucked up some sediment....
You could remove the blanket with the squeeze clips, un plug the hose, and try running the washer fluid. If the hose gushes with water then your nozzle is clogged.
1 - 2 of 2 Posts
