the spiral continues...
Wait did you just install a fresh 2014D install and it worked right away with the patch?
I have tried to get VIDA to install correctly on my laptop that I just installed Win10 and it simply hangs on the install...
I used the admin level to force installation under compatibility mode win7pro and was able to start the install, but it simply hang there forever until i force closed alba.exe process...
Can you help a bit with the missing part?
to remove the confusion; the second attempt is a fresh 2014D install on a W7Pro SP1 x64 desktop machine.
the 2014D install on the W10 Surface Pro is still faulty... though its 99% from being done! [sigh]
and that is what is frustrating about all this. even tho ive documented everything i was doing, every little change, bit by bit, as i went along...
on a whim, i turned around and got it up and running in about an hr on the desktop. just terribly maddening...
i am still trying to diagnose 2014D+IE11 in W10 on the Surface Pro.
its inability to connect to the communication tool once logged into VIDA is what is stopping me dead in my tracks.
given that i have tried my best to duplicate every setting and install on the fresh 2014D install on my W7Pro desktop... [that went without a hitch]
equally and more pertinent; ive never had the 2014D hang during install on my W10 Surface or W7Pro desktop:
- ensure W10 is up to date with everything from All Settings > Update & Security > Windows Update
- check your install log from C:\VIDA\System\Log\vida.install.2015-08-23.##.##.##.log [a text file]
it should tell the story of what is stopping/hanging up "alba.exe"
- check the driver and software versions of your install against my installed versions [up top]
IF STARTING A FRESH 2014D INSTALL:[W10 and W7]
- obtain and install Java 8 Update 60 [should be the latest]
- obtain a version of IE11 [theres one in the W10 program feature list] try to match the one i posted. or whatever is the latest.
- out of paranoia, i obtained and installed MSXML6.1
- obtain the latest
Microsoft® SQL Server® 2008 R2 SP2 - Express Edition [for me, SQLEXPRADV_x64_ENU.exe ~1GB] and install it FIRST.
- during that install, i configured a new installation. therein you can create an 'instance' called 'VIDA'.
follow through to set 'Mixed Mode' authentication and set the password as 'GunnarS3g3'.
set every SQL Server, Agent and Browser item to 'local SYSTEM' as much as possible during this time.
you can set it all in "Services" afterwards to ensure proper settings
- install all the tertiary components from the main install folder under 'VIDA Customize'
afterwards you should see three Setek AB DiCE USB components, Isoview, and Adobe Reader XI
- install VIDA 2014D from here: C:\VIDA\VIDA 2014D\Install\DVD\Vida_dvdheader\Vida and not from the 'Main' folder
set the install with administrator rights and compatibility mode for W7.
more to come...
edit: uninstalled skype
in "services":
turn off and disable:
IIS
World Wide Web Publishing service
IIS Admin Service
SQL Server Reporting services
Web Deployment Agent Service
