i would imagine, roll the window down, remove the door panel, unbolt from power window mechanism and pull it up and out.
Re: (peter_reece2003)
<IMG SRC="http://www.oneinhundred.com/upfiles/upimg5/Emergency-hammer-seatbelt-cutt-5812285.jpg" BORDER="0"><p>Works great on seatbelts too <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Front door panles: Remove all clips along side of the door by pusing in on the center of the clips. remove the cover that is on the door handle the part that goes north and south that you u use to close the door NOT the silver actual door handle. there will be two T25 torx screws there remove them then pull up on the panel over the door lock pin be sure to disconnect the handle clip and all wire conectors properly<p>Rear doors panels:Remove the door panel clip along the edge of the panel on the ouside of it. under the door handle in the lil cubby area there is a small panel you remove it and there is a T25 torx screw there remove it then slide the dorr panle upwards and over the locking pin and off. Be carefull not to rip off your door handle clip unclip it properly also undoo all wire conectors <p>All Doors: the window needs to be about half way down you will see a window slide rail that is silver (aluminum) and you will see two arm one on the left and one on the right there will be blue slide blocks in the rail(maybe white if replced with aftermarket ones before) there are metal clips pop them off they are tough to get off then pop out the arm from the block and rail repaet for other arm pull window out the top and reverse to install
Re: (97GLTbrick)
thank you '97 / <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
No problem it prolly has been about a month since i last did one at work but it should be really close to those directions
