no they won't fit over the R calipers without spacers. They will fit P2 cars tho.Im considering 18" tritons for my R but unsure if the center bore and offset are a good. Also want to be sure it will fit over calipers. Kindly advise. Thank you
Is it possible to get hubcentric 10mm spacers? IPD said they don't carry 10mm spacers because they can't be made hubcentric. Basically they don't want to deal with complaints from people who don't know how to properly torque down their wheels.No, I'm using them on my car. Get Hubcentric spacers if your going 10mm. 5mm you don't need hub centric, but you'll need extended bolts.
That doesn't make any sense, because a non-hub-centric 10mm spacer would be enough to push the wheel off the centering hub on the car, so there's nothing the wheel can center to. The wheel would then shift on the slightest pothole etc even if torqued properly, and cause severe vibrations. So I totally don't get what IPD is saying.Is it possible to get hubcentric 10mm spacers? IPD said they don't carry 10mm spacers because they can't be made hubcentric. Basically they don't want to deal with complaints from people who don't know how to properly torque down their wheels.
I think what they're getting at is the fact that the lip on the hub is about 9mm, which means that a 10mm hubcentric spacer is very thin at the point that is under the most strain, i.e. around the base of the lip on the spacer.That doesn't make any sense, because a non-hub-centric 10mm spacer would be enough to push the wheel off the centering hub on the car, so there's nothing the wheel can center to. The wheel would then shift on the slightest pothole etc even if torqued properly, and cause severe vibrations. So I totally don't get what IPD is saying.
Viva & EST carries hubcentric spacers.
http://www.vivaperformance.com/wheel-spacer-kit-10mm-m14x1-5/
http://www.eurosporttuning.ca/mm5/m...duct_Code=VLS-762-202&Category_Code=VL-S60-su
Right, actually now that you mentioned it, I remember the issue. I think the key is how the spacers are made. On the ones that I have which are Heico, the hub on the spacer has a beveled edge similar to what you find on the actual wheel hub.I think what they're getting at is the fact that the lip on the hub is about 9mm, which means that a 10mm hubcentric spacer is very thin at the point that is under the most strain, i.e. around the base of the lip on the spacer.
An example:
http://forums.swedespeed.com/showth...n-spacer-sheared-off-at-the-hubcentric-ring!&
I believe VIVA makes them.Is it possible to get hubcentric 10mm spacers? IPD said they don't carry 10mm spacers because they can't be made hubcentric. Basically they don't want to deal with complaints from people who don't know how to properly torque down their wheels.
My H&R spacers are HC and work great.Is it possible to get hubcentric 10mm spacers? IPD said they don't carry 10mm spacers because they can't be made hubcentric. Basically they don't want to deal with complaints from people who don't know how to properly torque down their wheels.
