1 - 8 of 8 Posts
· Registered
Re: will these tires fit my R? (Creap)
Quote, originally posted by Creap »
so I found some nice 20" wheels I like, the tire fitment for them is 245/35/20. Will that fit without major modification or rubbing? Thanks
it depends on the offset and all of that stuff I had 20" wheels on mine and they fit pretty good the only rubbing i got was like on a u turn.
· Registered
Re: will these tires fit my R? (BOOSTED S60R)
according to the website these wheels are supposed to fit. But they list the wheel in general and not a specific size, so I assume the 20's should fit.
· Registered
Ideally, you'd want 235/30/20. That would keep the rolling diameter about the same. 245/35 will dramatically change the rolling diameter and most likely will give you rubbing issues.
· Registered
post the website and i will look. My wheels were 20x8.5 44mm offset but i ran a 5 mm spacer on the front to clear the brake caliper. so be very careful when picking out wheels for this car.
1 - 8 of 8 Posts
